Keep documentation synchronized with your codebase
Learn how to keep technical documentation synchronized with your codebase using IBM Bob's init command and a custom Docs Architect mode across real development scenarios — feature work, code reviews, onboarding, and ongoing maintenance.
Documentation is often treated as an afterthought in software development—something you do after the code is "done." But in practice, documentation needs to evolve continuously alongside your code. This tutorial shows you how AI code documentation actually works in a practical development workflow using IBM Bob.
Rather than focusing on theory, you'll see how to integrate Bob's documentation capabilities into your daily development process: from initial project setup through feature development, code reviews, and releases. You'll use the /init command to establish AI-readable context and create a custom Docs Architect mode that generates human-readable documentation at each stage of development.
What you accomplish
In this tutorial, you learn how to:
- Set up AI code documentation as part of your development workflow
- Use
/initto create and maintain AI-readable project context - Build a custom Docs Architect mode for generating user-facing documentation
- Integrate documentation updates into feature development cycles
- Maintain documentation through code reviews and pull requests
- Keep documentation synchronized with code changes in version control
To complete this tutorial, you need the following:
- Bob IDE installed.
- A Git repository you want to document. Any local project or open source repository works.
How AI code documentation works in practice
Traditional documentation workflows separate writing code from writing docs. Developers write code, then (maybe) update documentation later. This creates a gap where documentation falls behind, becomes inaccurate, and eventually gets ignored.
IBM Bob is an IDE built to support the full software development lifecycle—and that includes AI code documentation. Bob makes documentation generation fast enough to happen alongside code changes, so docs stay current rather than falling behind. Here's how it works in practice:
The AI documentation workflow
- AI learns your codebase: The
/initcommand scans your repository and createsAGENTS.mdfiles—structured summaries that serve as knowledge bases for the large language model - AI generates documentation: Custom modes like Docs Architect use this context to generate user-facing documentation (READMEs, guides, API docs)
- You review and refine: AI-generated documentation is a starting point; you validate, edit, and commit it alongside code
- AI stays synchronized: Re-running
/initafter code changes updates the AI's understanding, enabling quick documentation updates
This workflow integrates documentation into your development process rather than treating it as a separate task.
Real-world scenarios
This tutorial walks through practical scenarios you'll encounter:
- Starting a new project: Setting up documentation from scratch
- Adding a feature: Updating docs as you develop
- Code review: Checking documentation in pull requests
- Onboarding: Using AI-generated docs to help new team members
- Maintenance: Keeping docs current as the codebase evolves
Scenario 1: Initial project documentation
You've inherited a repository with minimal documentation. New team members struggle to understand the codebase, and you need to create comprehensive documentation quickly.
Set up your workspace
- Open the repository in IBM Bob IDE.
- Open the Bob chat interface: Option + Command + B (macOS) or Ctrl + Alt + B (Windows)
Generate AI-readable context with /init
The first step is giving Bob knowledge about your project. Switch to Agent mode and run:
/initBob scans your repository and generates:
AGENTS.mdin the repository root (main project context).bob/rules-agent/AGENTS.md(Agent mode-specific context).bob/rules-plan/AGENTS.md(Plan mode-specific context).bob/rules-ask/AGENTS.md(Ask mode-specific context)
These files contain:
- Code structure and key directories
- Technology stack and dependencies
- Build, test, and lint commands
- Code patterns and conventions
Why this matters: These AGENTS.md files serve as knowledge bases that Bob references in every conversation. Instead of re-analyzing your entire codebase each time, Bob has persistent context about your project.
Review the generated context
Open AGENTS.md and review what Bob discovered:
cat AGENTS.mdYou'll see a structured summary of your project. If Bob missed important details (business rules, deployment conventions, team practices), edit AGENTS.md to add them. This file is meant to be customized.
Create a Docs Architect mode
Now create a custom mode that generates user-facing documentation. This mode will use the AGENTS.md context to create documentation for humans, not AI.
- Click the settings icon in the Bob panel to open Settings.
- Select the Modes tab.
- Click the + icon to create a new mode.
- Fill in the following values:
| Field | Value |
| Name | Docs Architect |
| Slug | docs-architect |
| Role Definition | You are a documentation architect and writer who creates user-facing documentation. You work alongside AGENTS.md files (created by /init) which provide AI-readable technical context. Your role is to create human-readable documentation that complements, not duplicates, the AGENTS.md content. You focus on user needs: getting started guides, conceptual overviews, tutorials, and onboarding materials. Include code snippets with clear explanations. Add JSDoc comments (JavaScript) or Javadoc (Java) and docstrings where helpful to improve code quality. |
| When to use | Use this mode for writing and maintaining user-facing documentation such as READMEs, onboarding guides, and API docs. Not for writing or modifying application code. |
| Available Tools | Read, Edit |
For the Mode-specific Custom Instructions field, copy and paste the following:
When documenting a project:
1. Review AGENTS.md files to understand project structure and technical details
2. Create user-facing documentation (READMEs, getting started guides, tutorials)
3. Avoid duplicating technical details from AGENTS.md (build commands, code patterns)
4. Focus on user workflows, conceptual overviews, and practical code examples
5. Include code blocks with clear explanations
6. Add docstrings and JSDoc comments to improve code quality
Generate:
- README.md explaining project purpose and navigation
- CONTRIBUTING.md with onboarding steps for new contributors
- Getting started guide with code snippets
- Conceptual documentation explaining architectural decisionsClick Save.
Bob creates a custom_modes.yaml file in .bob that contains the Docs Architect mode configuration. You can edit this file directly to make future changes.
Generate initial documentation
Switch to Docs Architect mode and prompt:
I've run /init to establish project context. Please create comprehensive documentation for this project:
1. Review AGENTS.md to understand the project structure
2. Create a README.md with:
- Project overview and purpose
- Quick start guide with code examples
- Project structure explanation
- Links to additional documentation
3. Create CONTRIBUTING.md with:
- Development setup instructions
- How to run tests
- How to submit a pull request
- Code style guidelines
4. Identify gaps in the codebase that need better documentation (missing docstrings, unclear functions)
Focus on making the technical details from AGENTS.md accessible to new developers.Bob generates documentation files. Review them for accuracy, make edits, then commit:
git add AGENTS.md .bob/ README.md CONTRIBUTING.md
git commit -m "docs: initial project documentation with AI assistance"Result: You've gone from minimal documentation to comprehensive docs in minutes, not hours.
Scenario 2: Documenting a new feature
You've just implemented a new feature. The code works, but your README, contributing guide, and API docs still describe the old state of the project. This is the most common point where documentation falls behind — the feature is done, but docs haven't caught up.
Here's how to close that gap using Bob.
Write the feature with Bob's help
While developing, switch to Agent mode so Bob can assist with the implementation. Because Bob already has project context from the /init you ran in Scenario 1, it understands your code structure, dependencies, and conventions — making its suggestions more relevant than starting from scratch.
Write the feature as you normally would, using Bob for code completion, refactoring, or asking questions about the existing codebase.
Re-run /init to update AI context
Once the feature is implemented, Bob's context is stale — it was generated before your new code existed. Update it:
/initBob rescans the repository and updates AGENTS.md to reflect what's changed — new modules, updated dependencies, and any new code patterns it detects.
Confirm the update captured your changes:
git diff AGENTS.md .bob/If the diff shows your new feature, Bob is ready to generate accurate documentation. If something important is missing, edit AGENTS.md manually before continuing.
Generate documentation for the new feature
Now switch to Docs Architect mode. Because you've just updated AGENTS.md, Bob has an accurate picture of the new feature and can generate documentation that reflects the real implementation — not a guess.
Prompt Bob with what needs updating:
I've added a new feature to the project. Please update the documentation:
1. Add a section to README.md explaining:
- What the feature does
- How to configure and use it
- A code snippet showing basic usage
2. Update CONTRIBUTING.md if the development workflow has changed
3. Create a dedicated docs page that covers:
- How the feature works
- Relevant API endpoints or interfaces
- Code examples for common use cases
- Code explanations for non-obvious logic
- Troubleshooting tips
Include code blocks with clear explanations. Add docstrings to any functions that lack them.Review the generated documentation for accuracy — check that code examples actually match your implementation — then commit everything together:
git add src/ AGENTS.md .bob/ README.md CONTRIBUTING.md docs/
git commit -m "feat: add [feature name] with documentation"Result: Your feature and its documentation are developed together and committed in the same pull request.
Scenario 3: Code review with documentation checks
A team member submits a pull request that adds a new API endpoint. You need to ensure the documentation is updated.
Review the code changes
git diff main feature-branchYou see new API endpoints but no documentation updates.
Check if /init was run
git diff main feature-branch -- AGENTS.md .bob/If there are no changes to AGENTS.md, the developer didn't run /init. Ask them to:
- Run
/initto update AI context - Use Docs Architect to update user-facing docs
Generate missing documentation
If you're reviewing the PR, you can generate the documentation yourself:
git checkout feature-branchIn Bob, run /init, then switch to Docs Architect mode:
I'm reviewing a pull request that adds new API endpoints. Please update the documentation:
1. Review the new endpoints in src/api/
2. Update README.md with a brief mention of the new endpoints
3. Update docs/api.md with:
- Endpoint descriptions
- Request/response examples with code blocks
- Authentication requirements
- Error codes
4. Add JSDoc comments to the endpoint handlers if missing
Focus on making the API easy to understand for other developers.Commit the documentation updates:
git add AGENTS.md .bob/ README.md docs/api.md src/api/
git commit -m "docs: add documentation for new API endpoints"
git pushResult: Documentation is part of your code review process, not an afterthought.
Scenario 4: Onboarding a new team member
A new developer joins your team. They need to understand the codebase quickly.
Have them run /init
The new developer clones the repository and runs:
/initBob generates fresh AGENTS.md files that reflect the current state of the codebase. The new developer can now:
- Read
AGENTS.mdto understand project structure - Read
README.mdfor getting started instructions - Read
CONTRIBUTING.mdfor development workflow
Use Ask mode for exploration
The new developer can use Bob's Ask mode to explore the codebase:
@src/auth Explain how authentication works in this project@src/api What API endpoints are available and what do they do?@tests How do I run tests for a specific module?Bob answers using the context from AGENTS.md and the actual source code.
Generate personalized onboarding docs
If your project lacks onboarding documentation, use Docs Architect:
Create an onboarding guide for new developers joining this project:
1. Prerequisites (tools, accounts, access)
2. Initial setup steps with code blocks
3. How to run the project locally
4. How to run tests
5. Overview of the codebase structure
6. Common development tasks with examples
7. Where to find help
Make it practical and include code snippets for each step.Result: New team members can get up to speed in hours instead of days.
Scenario 5: Maintaining documentation over time
Your project has been in development for months. Code has changed significantly, and documentation is starting to drift.
Detect documentation drift
Run /init to see what's changed:
/initReview the diff:
git diff AGENTS.md .bob/Large changes indicate significant code evolution. This is your signal that user-facing documentation needs updates.
Update documentation systematically
Use Docs Architect to refresh documentation:
I've run /init and noticed significant changes to the project structure. Please review and update the documentation:
1. Review AGENTS.md changes to understand what's different
2. Update README.md to reflect current project structure
3. Update CONTRIBUTING.md if development workflow has changed
4. Identify any new features that lack documentation
5. Remove documentation for deprecated features
6. Update code examples to match current API
Focus on accuracy—make sure documentation matches the current codebase.Establish a maintenance schedule
Add documentation updates to your regular workflow:
- Monthly: Run
/initand review changes - Before releases: Update all documentation
- After major refactors: Regenerate affected documentation
- In code reviews: Check if
/initwas run and docs were updated
Automate drift detection (advanced)
For teams that want to enforce documentation hygiene in CI, add a pull request check that verifies AGENTS.md and .bob/ are up to date. The check would run /init against the branch, then fail if the output differs from what was committed — signaling that the developer forgot to update AI context before opening the PR. Pair this with the PR template checklist from the best practices section to make documentation updates a required part of your review process.
Result: Documentation stays synchronized with code through regular maintenance.
Best practices for AI code documentation workflows
Integrate /init into your development process
Make /init a regular part of your workflow:
- Run it after adding new modules or features
- Run it after major refactors
- Run it before creating pull requests
- Run it monthly for active projects
Commit AI context and user docs together
Always commit AGENTS.md files alongside user-facing documentation:
git commit -m "docs: update for [feature/change]"This keeps both layers synchronized in your version control system and makes your repository self-documenting for tools like Mintlify that generate API documentation from Markdown source files.
Treat AI-generated docs as drafts
AI-powered code documentation tools generate starting points, not final products. Always:
- Review for accuracy
- Check code examples work
- Verify technical details
- Adjust tone and style
- Add context AI might miss
Use context mentions for precision
When updating specific parts of documentation, use @ mentions:
@src/auth @docs/authentication.md Update the authentication documentation to reflect the new OAuth flowThis helps Bob focus on relevant code and documentation.
Include documentation in code reviews
Add documentation checks to your pull request template:
## Documentation Checklist
- [ ] Ran `/init` to update AGENTS.md
- [ ] Updated README if user-facing changes
- [ ] Updated API docs if endpoints changed
- [ ] Added code examples for new features
- [ ] Verified all code snippets workMaintain code quality with docstrings
Use Bob to add docstrings and JSDoc comments:
@src/api Review all functions in this directory and add JSDoc comments to any that lack them. Include parameter types, return types, and usage examples.This improves both code quality and documentation.
Troubleshooting common scenarios
Documentation doesn't match the code
Problem: Generated documentation describes features that don't exist or misses recent changes.
Solution:
- Run
/initto update AI context - Review
AGENTS.mdchanges to see what Bob detected - Regenerate affected documentation with Docs Architect
- Manually verify code examples work
/init misses important context
Problem: AGENTS.md lacks project-specific details like business rules or deployment conventions.
Solution: Edit AGENTS.md manually to add context /init couldn't detect. This file is meant to be customized.
Documentation updates take too long
Problem: Regenerating documentation for large projects is time-consuming.
Solution: Use context mentions to update specific sections:
@docs/api.md @src/api/users.ts Update only the user API documentation to reflect the new endpointsTeam members forget to update docs
Problem: Pull requests lack documentation updates.
Solution:
- Add documentation checks to PR template
- Set up CI checks that verify
/initwas run - Make documentation review part of code review process
AI generates incorrect code examples
Problem: Code snippets in documentation don't work or use deprecated APIs.
Solution:
- Always test generated code examples
- Use context mentions to point Bob at current code:
@src/api/current-implementation.ts - Update the Docs Architect mode instructions to emphasize accuracy
Next steps
You've learned how AI code documentation works in practice using IBM Bob. You've seen how to:
- Integrate
/initinto your development workflow - Use custom modes to generate user-facing documentation
- Maintain documentation through feature development and code reviews
Apply this workflow to your projects
- Start with /init: Run it on your current project
- Create your mode: Customize Docs Architect for your team's needs
- Document as you develop: Update docs alongside code changes
- Review in PRs: Make documentation part of code review
- Maintain regularly: Schedule monthly
/initruns
Create a new context window
Manage Bob's context window to preserve memory, control cost, and maintain output quality during complex or long-running conversations.
Tools
Learn how Bob uses specialized tools to read files, edit code, run commands, spawn subagents, use MCP integrations, and switch modes to streamline your coding workflow.
